MBRS485 Direction Control on UART1
Added by Michael B about 2 years ago
Hi all,
My application requires installation embedded in a battery power system with long wire. I would like access to UART1 over the wire, which we have decided to use half duplex RS-485 for. Is there a way to make the UART1 integrate a GPIO pin to toggle the direction control pin on my RS-485 transceiver? I understand that my application level code running on the system could easily implement this, but is there a way to tell the linux/uBoot software/firmware to do this as well? I thought maybe the UART1_RTS# signal could be used, but my application is audio related and would like that pin to be used for its intended function as the McASP Receive Master Clock..
If this is not possible, are we able to change which UART is used by the system? UART0 with RTS enabled might be preferred for my application...
I appreciate any insights, workarounds, or referrals!
Thank you,
Michael
Replies (5)
JC RE: RS485 Direction Control on UART1 - Added by Jonathan Cormier about 2 years ago
The serial 8250 driver has an rs485 mode which we extended to allow using a gpio to generate a RS485 TX enable. However this was intended to be setup at runtime for a separate interface and not for the debug console. Though you may be able to tweak the driver to allow this mode to be set up in the baseboard file..
https://support.criticallink.com/redmine/boards/10/topics/1273?r=1276#message-1276
https://support.criticallink.com/gitweb/?p=linux-davinci.git;a=commit;h=685560d539688afc6bd5a735d4059c99eed24758
I'm not sure if I'd recommend this approach as you'll also need to modify the u-boot code to do something similar and possibly the UBL code, to see the whole boot process.
For similar reasons, I always push back on any design that tries to move the debug UART to a different port. A successful bring-up is very reliant on the debug UART working and making changes like this can add a ton of delays to development, when things don't work.
So yes it's possible but I would not want to bring up such a system.
Could you do an RS422 4-wire bus instead? You then wouldn't need the TXEN pin, so no software changes.
MB RE: RS485 Direction Control on UART1 - Added by Michael B about 2 years ago
Hi Jonathan,
thanks for the quick response. I will look into the 8250 driver, it might be useful (if only for my runtime code). I expected a hesitant response with regard to this scheme, but half duplex RS485 is unfortunately the most suited interface we can implement (long distance, low power, and few wires). The primary motivation for getting UART1 access over the RS485 interface is the ability to reconfigure the SOM entirely while it is embedded in our system. For development we could work with UART1 conventionally and have RS485 setup on a different UART for interfacing with our software. This is likely what I will shoot for now, but the ability to reconfigure the SOM in its embedded state is very desirable. Any outside-of-the-box insight on how that could be accomplished over one RS485 link would be appreciated!
Thank you,
Michael
How long are you looking for?
The kernel documentation mentions getting extended distance for rs232 by using UTP cat 5 cable. Or using a shield low-capacitance wire. Also mentions using line drivers to get larger distances.
https://tldp.org/HOWTO/Remote-Serial-Console-HOWTO/serial-distance.html
We could also drop the data rate but that would require almost the same amount of code change.
I did come across this application note from TI: https://www.ti.com/lit/ug/tidubw6/tidubw6.pdf?ts=1719509747706
(if the link is broken in the future to others with this need, the article is titled: "TIDUBW6 - June 2016: TI Designs Automatic Direction Control RS-485")
I made some modifications of their example design to work with 3.3V and 115200 baud, 1 stop, no parity.I believe this should work quite well for the application.
Instead of a 555, I opted to use a LTC6993-3.
Seems like it could work. Good find.
