YLWhere to download the document about Memory Map and Register Address of IO Board 80-000268RI-2C and OMAPL138F
Added by yanqing lu about 12 years ago
only some brief documents are found in wiki,
Where can I download the document about Memory Map and Register Address of the IO Board 80-000268RI-2C and OMAPL138F?
MW RE: Where to download the document about Memory Map and Register Address of IO Board 80-000268RI-2C and OMAPL138F - Added by Michael Williamson about 12 years ago
The memory map of the OMAP-L138 can be found on TI's main OMAP-L138 web page (see the datasheet and the technical reference manual).
Not sure if that is what you are looking for.
JC RE: Where to download the document about Memory Map and Register Address of IO Board 80-000268RI-2C and OMAPL138F - Added by Jonathan Cormier about 12 years ago
These are provided by TI. You can find them here: http://www.ti.com/product/OMAP-L138/technicaldocuments
You should start with the "OMAP-L138 C6000 DSP+ARM Processor (Rev. H)" Datasheet and the "OMAP-L138 C6000 DSP+ARM Processor Technical Reference Manual (Rev. A)". In my experience these are good starting points when looking for the L138 memory maps and such.
    (1-2/2)
