NK"Regarding developing real time application"
Added by Naveen K.S over 12 years ago
Dear sir,
we are working on developing vision system, wherein we are using your mitydsp L138F SOM and Industrial I/o Board (as a sub system module in our entire system) for image processing. Our requirement is we need to interact with other subsystems of our entire system as well via UART of mitydsp L138F board. That is we need to transmit and receive updated data from other subsystem modules to mitydsp l138f board module and perform this obtained data overlay on output video. So my question is how to do this real time ARM9 programming with out using your Qt based ARM frame work. Can you help us with documentation and in depth details to achieve our requirement as we are newbies to this technology.
Thanking you in advance
with best regards,
Naveen K.S.
MW RE: "Regarding developing real time application" - Added by Michael Williamson over 12 years ago
Do you mean using a UART from Linux? Or are you trying to use the UART with the DSP?
I'm afraid we can't help you design your application without detailed requirements.
NK RE: "Regarding developing real time application" - Added by Naveen K.S over 12 years ago
Hi Mike,
We are planning UART from linux on arm9 cortex. Or can you suggest any feasible solution in this regard, as we are planning DSP only for image algorithms.
With regards,
Naveen K S
