ZCHigh speed USB port issue on MityDSPL138
Added by Zoltan Csizmadia almost 16 years ago
Hi All,
I try to attach a USB memory on the high speed port (OTG port in host mode), but the memory is not recognized at all. If I do the same on the FS OHCI host, there is no problem, device is attached and file system recognized.
I cannot measure the 5V on the connector in host mode, and I'm not using any special OTG cable, should I short the ID pin to ground in my cable?
BTW, where can I find the schematics for the MityDSL138 module and/or development mother board?
Best regards,
Zoltan
Here is my boot log and linux .config:
Linux version 2.6.34-rc1 (zoltan@zoltandev) (gcc version 4.5.1 (Sourcery G++ Lit
e 2010.09-50) ) #2 PREEMPT Fri Jan 14 10:13:05 CST 2011
Machine: MityDSP-L138
Peripheral Config Block Found
Enet_Config = 2
PHYMask = 0x8
No LCD Configured
UART0 = 0, 0, 0, 115200
UART1 = 1, 1, 0, 115200
UART2 = 0, 0, 0, 115200
SPI0 = 0, 0, 00, 0, 0
SPI1 = 1, 1, 01, 0, 30000000
DaVinci da850/omap-l138 variant 0x0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 28448
Kernel command line: mem=112M console=ttyS1,115200n8 root=/dev/ram0 rw initrd=0xc1180000,8M
PID hash table entries: 512 (order: 1, 2048 bytes)
Memory: 112MB = 112MB total
Memory: 102320k/102320k available, 12368k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xff000000 - 0xffe00000 ( 14 MB)
vmalloc : 0xc7800000 - 0xfea00000 ( 882 MB)
lowmem : 0xc0000000 - 0xc7000000 ( 112 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc0025000 ( 116 kB)
.text : 0xc0025000 - 0xc02bf000 (2664 kB)
.data : 0xc02d4000 - 0xc02f4aa0 ( 131 kB)
Experimental preemptable hierarchical RCU implementation.
NR_IRQS:245
Calibrating delay loop... 149.50 BogoMIPS (lpj=747520)
DaVinci: 144 gpio irqs
regulator: core version 0.5
mityomapl138_init...
EMAC: MII PHY configured, RMII PHY will not be functional
mityomapl138_init: setting phy_mask to 8
mityomapl138_init: no LCD device enabled
bio: create slab <bio-0> at 0
SCSI subsystem initialized
regulator: VDCDC1: 1150 <-
> 1350 mV at 1200 mV
regulator: VDCDC2: 1710 <--> 1910 mV at 3300 mV
regulator: VDCDC3: 1120 <--> 1320 mV at 1800 mV
regulator: LDO1: 1800 mV
regulator: LDO2: 3300 mV
musb_hdrc: version 6.0, cppi4.1-dma, host, debug=0
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 8192K
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 215
console [ttyS1] enabled
brd: module loaded
loop: module loaded
at24 1-0050: 256 byte 24c02 EEPROM (read-only)
MityOMAPL138: Found MAC = 00:50:c2:bf:89:05
MityOMAPL138: Part Number = L138-CG-225-RC
MityOMAPL138: setting max frequency to 300 MHz
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron NAND 256MiB 3,3V 16-bit)
Creating 2 MTD partitions on "davinci_nand.0":
0x000008000000-0x000010000000 : "homefs"
davinci_nand davinci_nand.0: controller rev. 2.5
m25p80 spi1.0: m25p64 (8192 Kbytes)
Creating 3 MTD partitions on "m25p80":
0x000000000000-0x000000010000 : "UBL"
0x000000010000-0x000000090000 : "U-Boot"
0x000000090000-0x000000800000 : "Spare"
ohci ohci.0: DA8xx OHCI
ohci ohci.0: new USB bus registered, assigned bus number 2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
omap_rtc: already running
i2c /dev entries driver
cpuidle: using governor menu
TCP cubic registered
Clocks: disable unused i2c1
Clocks: disable unused emac
Clocks: disable unused mcasp
Clocks: disable unused lcdc
Clocks: disable unused spi0
Clocks: disable unused mcbsp0
Clocks: disable unused mcbsp1
Clocks: disable unused vpif
regulator_init_complete: incomplete constraints, leaving LDO2 on
regulator_init_complete: incomplete constraints, leaving LDO1 on
regulator_init_complete: incomplete constraints, leaving VDCDC3 on
regulator_init_complete: incomplete constraints, leaving VDCDC2 on
regulator_init_complete: incomplete constraints, leaving VDCDC1 on
emac-mii: probed
omap_rtc omap_rtc: setting system clock to 2010-05-10 02:44:16 UTC (1273459456)
RAMDISK: gzip image found at block 0
VFS: Mounted root (ext2 filesystem) on device 1:0.
Freeing init memory: 116K
Please press Enter to activate this console.
  1. Automatically generated make config: don't edit
  2. Linux kernel version: 2.6.34-rc1
  3. Fri Jan 14 10:12:10 2011 #
    CONFIG_ARM=y
    CONFIG_SYS_SUPPORTS_APM_EMULATION=y
    CONFIG_GENERIC_GPIO=y
    CONFIG_GENERIC_TIME=y
    CONFIG_GENERIC_CLOCKEVENTS=y
    CONFIG_HAVE_PROC_CPU=y
    CONFIG_GENERIC_HARDIRQS=y
    CONFIG_STACKTRACE_SUPPORT=y
    CONFIG_HAVE_LATENCYTOP_SUPPORT=y
    CONFIG_LOCKDEP_SUPPORT=y
    CONFIG_TRACE_IRQFLAGS_SUPPORT=y
    CONFIG_HARDIRQS_SW_RESEND=y
    CONFIG_GENERIC_IRQ_PROBE=y
    CONFIG_RWSEM_GENERIC_SPINLOCK=y
    CONFIG_ARCH_HAS_CPUFREQ=y
    CONFIG_GENERIC_HWEIGHT=y
    CONFIG_GENERIC_CALIBRATE_DELAY=y
    CONFIG_ZONE_DMA=y
    CONFIG_GENERIC_HARDIRQS_NO__DO_IRQ=y
    CONFIG_VECTORS_BASE=0xffff0000
    CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
    CONFIG_CONSTRUCTORS=y
  1. General setup #
    CONFIG_EXPERIMENTAL=y
    CONFIG_BROKEN_ON_SMP=y
    CONFIG_LOCK_KERNEL=y
    CONFIG_INIT_ENV_ARG_LIMIT=32
    CONFIG_LOCALVERSION=""
    CONFIG_LOCALVERSION_AUTO=y
    CONFIG_HAVE_KERNEL_GZIP=y
    CONFIG_HAVE_KERNEL_LZO=y
    CONFIG_KERNEL_GZIP=y
  2. CONFIG_KERNEL_BZIP2 is not set
  3. CONFIG_KERNEL_LZMA is not set
  4. CONFIG_KERNEL_LZO is not set
  5. CONFIG_SWAP is not set
    CONFIG_SYSVIPC=y
    CONFIG_SYSVIPC_SYSCTL=y
    CONFIG_POSIX_MQUEUE=y
    CONFIG_POSIX_MQUEUE_SYSCTL=y
  6. CONFIG_BSD_PROCESS_ACCT is not set
  7. CONFIG_TASKSTATS is not set
  8. CONFIG_AUDIT is not set
  1. RCU Subsystem #
  2. CONFIG_TREE_RCU is not set
    CONFIG_TREE_PREEMPT_RCU=y
  3. CONFIG_TINY_RCU is not set
  4. CONFIG_RCU_TRACE is not set
    CONFIG_RCU_FANOUT=32
  5. CONFIG_RCU_FANOUT_EXACT is not set
  6. CONFIG_TREE_RCU_TRACE is not set
    CONFIG_IKCONFIG=y
    CONFIG_IKCONFIG_PROC=y
    CONFIG_LOG_BUF_SHIFT=14
  7. CONFIG_CGROUPS is not set
  8. CONFIG_SYSFS_DEPRECATED_V2 is not set
  9. CONFIG_RELAY is not set
  10. CONFIG_NAMESPACES is not set
    CONFIG_BLK_DEV_INITRD=y
    CONFIG_INITRAMFS_SOURCE=""
    CONFIG_RD_GZIP=y
  11. CONFIG_RD_BZIP2 is not set
  12. CONFIG_RD_LZMA is not set
  13. CONFIG_RD_LZO is not set
    CONFIG_CC_OPTIMIZE_FOR_SIZE=y
    CONFIG_SYSCTL=y
    CONFIG_ANON_INODES=y
    CONFIG_EMBEDDED=y
    CONFIG_UID16=y
    CONFIG_SYSCTL_SYSCALL=y
    CONFIG_KALLSYMS=y
  14. CONFIG_KALLSYMS_ALL is not set
  15. CONFIG_KALLSYMS_EXTRA_PASS is not set
    CONFIG_HOTPLUG=y
    CONFIG_PRINTK=y
    CONFIG_BUG=y
    CONFIG_ELF_CORE=y
    CONFIG_BASE_FULL=y
    CONFIG_FUTEX=y
    CONFIG_EPOLL=y
    CONFIG_SIGNALFD=y
    CONFIG_TIMERFD=y
    CONFIG_EVENTFD=y
    CONFIG_SHMEM=y
    CONFIG_AIO=y
    CONFIG_HAVE_PERF_EVENTS=y
    CONFIG_PERF_USE_VMALLOC=y
  1. Kernel Performance Events And Counters #
  2. CONFIG_PERF_EVENTS is not set
  3. CONFIG_PERF_COUNTERS is not set
    CONFIG_VM_EVENT_COUNTERS=y
    CONFIG_COMPAT_BRK=y
    CONFIG_SLAB=y
  4. CONFIG_SLUB is not set
  5. CONFIG_SLOB is not set
  6. CONFIG_PROFILING is not set
    CONFIG_HAVE_OPROFILE=y
  7. CONFIG_KPROBES is not set
    CONFIG_HAVE_KPROBES=y
    CONFIG_HAVE_KRETPROBES=y
    CONFIG_HAVE_CLK=y
  1. GCOV-based kernel profiling #
  2. CONFIG_GCOV_KERNEL is not set
  3. CONFIG_SLOW_WORK is not set
    CONFIG_HAVE_GENERIC_DMA_COHERENT=y
    CONFIG_SLABINFO=y
    CONFIG_RT_MUTEXES=y
    CONFIG_BASE_SMALL=0
    CONFIG_MODULES=y
  4. CONFIG_MODULE_FORCE_LOAD is not set
    CONFIG_MODULE_UNLOAD=y
    CONFIG_MODULE_FORCE_UNLOAD=y
  5. CONFIG_MODVERSIONS is not set
  6. CONFIG_MODULE_SRCVERSION_ALL is not set
    CONFIG_BLOCK=y
    CONFIG_LBDAF=y
  7. CONFIG_BLK_DEV_BSG is not set
  8. CONFIG_BLK_DEV_INTEGRITY is not set
  1. IO Schedulers #
    CONFIG_IOSCHED_NOOP=y
  2. CONFIG_IOSCHED_DEADLINE is not set
  3. CONFIG_IOSCHED_CFQ is not set
  4. CONFIG_DEFAULT_DEADLINE is not set
  5. CONFIG_DEFAULT_CFQ is not set
    CONFIG_DEFAULT_NOOP=y
    CONFIG_DEFAULT_IOSCHED="noop"
  6. CONFIG_INLINE_SPIN_TRYLOCK is not set
  7. CONFIG_INLINE_SPIN_TRYLOCK_BH is not set
  8. CONFIG_INLINE_SPIN_LOCK is not set
  9. CONFIG_INLINE_SPIN_LOCK_BH is not set
  10. CONFIG_INLINE_SPIN_LOCK_IRQ is not set
  11. CONFIG_INLINE_SPIN_LOCK_IRQSAVE is not set
  12. CONFIG_INLINE_SPIN_UNLOCK is not set
  13. CONFIG_INLINE_SPIN_UNLOCK_BH is not set
  14. CONFIG_INLINE_SPIN_UNLOCK_IRQ is not set
  15. CONFIG_INLINE_SPIN_UNLOCK_IRQRESTORE is not set
  16. CONFIG_INLINE_READ_TRYLOCK is not set
  17. CONFIG_INLINE_READ_LOCK is not set
  18. CONFIG_INLINE_READ_LOCK_BH is not set
  19. CONFIG_INLINE_READ_LOCK_IRQ is not set
  20. CONFIG_INLINE_READ_LOCK_IRQSAVE is not set
  21. CONFIG_INLINE_READ_UNLOCK is not set
  22. CONFIG_INLINE_READ_UNLOCK_BH is not set
  23. CONFIG_INLINE_READ_UNLOCK_IRQ is not set
  24. CONFIG_INLINE_READ_UNLOCK_IRQRESTORE is not set
  25. CONFIG_INLINE_WRITE_TRYLOCK is not set
  26. CONFIG_INLINE_WRITE_LOCK is not set
  27. CONFIG_INLINE_WRITE_LOCK_BH is not set
  28. CONFIG_INLINE_WRITE_LOCK_IRQ is not set
  29. CONFIG_INLINE_WRITE_LOCK_IRQSAVE is not set
  30. CONFIG_INLINE_WRITE_UNLOCK is not set
  31. CONFIG_INLINE_WRITE_UNLOCK_BH is not set
  32. CONFIG_INLINE_WRITE_UNLOCK_IRQ is not set
  33. CONFIG_INLINE_WRITE_UNLOCK_IRQRESTORE is not set
  34. CONFIG_MUTEX_SPIN_ON_OWNER is not set
  35. CONFIG_FREEZER is not set
  1. System Type #
    CONFIG_MMU=y
  2. CONFIG_ARCH_AAEC2000 is not set
  3. CONFIG_ARCH_INTEGRATOR is not set
  4. CONFIG_ARCH_REALVIEW is not set
  5. CONFIG_ARCH_VERSATILE is not set
  6. CONFIG_ARCH_AT91 is not set
  7. CONFIG_ARCH_CLPS711X is not set
  8. CONFIG_ARCH_GEMINI is not set
  9. CONFIG_ARCH_EBSA110 is not set
  10. CONFIG_ARCH_EP93XX is not set
  11. CONFIG_ARCH_FOOTBRIDGE is not set
  12. CONFIG_ARCH_MXC is not set
  13. CONFIG_ARCH_STMP3XXX is not set
  14. CONFIG_ARCH_NETX is not set
  15. CONFIG_ARCH_H720X is not set
  16. CONFIG_ARCH_NOMADIK is not set
  17. CONFIG_ARCH_IOP13XX is not set
  18. CONFIG_ARCH_IOP32X is not set
  19. CONFIG_ARCH_IOP33X is not set
  20. CONFIG_ARCH_IXP23XX is not set
  21. CONFIG_ARCH_IXP2000 is not set
  22. CONFIG_ARCH_IXP4XX is not set
  23. CONFIG_ARCH_L7200 is not set
  24. CONFIG_ARCH_DOVE is not set
  25. CONFIG_ARCH_KIRKWOOD is not set
  26. CONFIG_ARCH_LOKI is not set
  27. CONFIG_ARCH_MV78XX0 is not set
  28. CONFIG_ARCH_ORION5X is not set
  29. CONFIG_ARCH_MMP is not set
  30. CONFIG_ARCH_KS8695 is not set
  31. CONFIG_ARCH_NS9XXX is not set
  32. CONFIG_ARCH_W90X900 is not set
  33. CONFIG_ARCH_NUC93X is not set
  34. CONFIG_ARCH_PNX4008 is not set
  35. CONFIG_ARCH_PXA is not set
  36. CONFIG_ARCH_MSM is not set
  37. CONFIG_ARCH_RPC is not set
  38. CONFIG_ARCH_SA1100 is not set
  39. CONFIG_ARCH_S3C2410 is not set
  40. CONFIG_ARCH_S3C64XX is not set
  41. CONFIG_ARCH_S5PC1XX is not set
  42. CONFIG_ARCH_SHARK is not set
  43. CONFIG_ARCH_LH7A40X is not set
  44. CONFIG_ARCH_U300 is not set
    CONFIG_ARCH_DAVINCI=y
  45. CONFIG_ARCH_OMAP is not set
  46. CONFIG_ARCH_BCMRING is not set
  47. CONFIG_ARCH_U8500 is not set
    CONFIG_CP_INTC=y
  1. TI DaVinci Implementations #
  1. DaVinci Core Type #
  2. CONFIG_ARCH_DAVINCI_DM644x is not set
  3. CONFIG_ARCH_DAVINCI_DM355 is not set
  4. CONFIG_ARCH_DAVINCI_DM646x is not set
    CONFIG_ARCH_DAVINCI_DA830=y
    CONFIG_ARCH_DAVINCI_DA850=y
    CONFIG_ARCH_DAVINCI_DA8XX=y
  5. CONFIG_ARCH_DAVINCI_DM365 is not set
  1. DaVinci Board Type #
  2. CONFIG_MACH_DAVINCI_DA830_EVM is not set
  3. CONFIG_MACH_DAVINCI_DA850_EVM is not set
    CONFIG_MACH_MITYOMAPL138=y
    CONFIG_DAVINCI_MUX=y
  4. CONFIG_DAVINCI_MUX_DEBUG is not set
  5. CONFIG_DAVINCI_MUX_WARNINGS is not set
    CONFIG_DAVINCI_RESET_CLOCKS=y
  6. CONFIG_DAVINCI_MCBSP is not set
  1. Processor Type #
    CONFIG_CPU_ARM926T=y
    CONFIG_CPU_32v5=y
    CONFIG_CPU_ABRT_EV5TJ=y
    CONFIG_CPU_PABRT_LEGACY=y
    CONFIG_CPU_CACHE_VIVT=y
    CONFIG_CPU_COPY_V4WB=y
    CONFIG_CPU_TLB_V4WBI=y
    CONFIG_CPU_CP15=y
    CONFIG_CPU_CP15_MMU=y
  1. Processor Features #
    CONFIG_ARM_THUMB=y
  2. CONFIG_CPU_ICACHE_DISABLE is not set
  3. CONFIG_CPU_DCACHE_DISABLE is not set
    CONFIG_CPU_DCACHE_WRITETHROUGH=y
  4. CONFIG_CPU_CACHE_ROUND_ROBIN is not set
    CONFIG_ARM_L1_CACHE_SHIFT=5
    CONFIG_COMMON_CLKDEV=y
  1. Bus support #
  2. CONFIG_PCI_SYSCALL is not set
  3. CONFIG_ARCH_SUPPORTS_MSI is not set
  4. CONFIG_PCCARD is not set
  1. Kernel Features #
    CONFIG_TICK_ONESHOT=y
    CONFIG_NO_HZ=y
    CONFIG_HIGH_RES_TIMERS=y
    CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
    CONFIG_VMSPLIT_3G=y
  2. CONFIG_VMSPLIT_2G is not set
  3. CONFIG_VMSPLIT_1G is not set
    CONFIG_PAGE_OFFSET=0xC0000000
  4. CONFIG_PREEMPT_NONE is not set
  5. CONFIG_PREEMPT_VOLUNTARY is not set
    CONFIG_PREEMPT=y
    CONFIG_HZ=100
    CONFIG_AEABI=y
  6. CONFIG_OABI_COMPAT is not set
    CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
  7. CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
  8. CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
  9. CONFIG_HIGHMEM is not set
    CONFIG_SELECT_MEMORY_MODEL=y
    CONFIG_FLATMEM_MANUAL=y
  10. CONFIG_DISCONTIGMEM_MANUAL is not set
  11. CONFIG_SPARSEMEM_MANUAL is not set
    CONFIG_FLATMEM=y
    CONFIG_FLAT_NODE_MEM_MAP=y
    CONFIG_PAGEFLAGS_EXTENDED=y
    CONFIG_SPLIT_PTLOCK_CPUS=999999
  12. CONFIG_PHYS_ADDR_T_64BIT is not set
    CONFIG_ZONE_DMA_FLAG=1
    CONFIG_BOUNCE=y
    CONFIG_VIRT_TO_BUS=y
  13. CONFIG_KSM is not set
    CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
    CONFIG_LEDS=y
  14. CONFIG_LEDS_CPU is not set
    CONFIG_ALIGNMENT_TRAP=y
  15. CONFIG_UACCESS_WITH_MEMCPY is not set
  1. Boot options #
    CONFIG_ZBOOT_ROM_TEXT=0x0
    CONFIG_ZBOOT_ROM_BSS=0x0
    CONFIG_CMDLINE=""
  2. CONFIG_XIP_KERNEL is not set
  3. CONFIG_KEXEC is not set
  1. CPU Power Management #
    CONFIG_CPU_FREQ=y
    CONFIG_CPU_FREQ_TABLE=y
  2. CONFIG_CPU_FREQ_DEBUG is not set
    CONFIG_CPU_FREQ_STAT=y
  3. CONFIG_CPU_FREQ_STAT_DETAILS is not set
  4. CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
  5. CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
    CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE=y
  6. CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
  7. CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
  8. CONFIG_CPU_FREQ_GOV_PERFORMANCE is not set
  9. CONFIG_CPU_FREQ_GOV_POWERSAVE is not set
    CONFIG_CPU_FREQ_GOV_USERSPACE=y
  10. CONFIG_CPU_FREQ_GOV_ONDEMAND is not set
  11. CONFIG_CPU_FREQ_GOV_CONSERVATIVE is not set
    CONFIG_CPU_IDLE=y
    CONFIG_CPU_IDLE_GOV_LADDER=y
    CONFIG_CPU_IDLE_GOV_MENU=y
  1. Floating point emulation #
  1. At least one emulation must be selected #
  2. CONFIG_VFP is not set
  1. Userspace binary formats #
    CONFIG_BINFMT_ELF=y
  2. CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
    CONFIG_HAVE_AOUT=y
  3. CONFIG_BINFMT_AOUT is not set
  4. CONFIG_BINFMT_MISC is not set
  1. Power management options #
  2. CONFIG_PM is not set
    CONFIG_ARCH_SUSPEND_POSSIBLE=y
    CONFIG_NET=y
  1. Networking options #
    CONFIG_PACKET=y
    CONFIG_UNIX=y
    CONFIG_XFRM=y
  2. CONFIG_XFRM_USER is not set
  3. CONFIG_XFRM_SUB_POLICY is not set
  4. CONFIG_XFRM_MIGRATE is not set
  5. CONFIG_XFRM_STATISTICS is not set
  6. CONFIG_NET_KEY is not set
    CONFIG_INET=y
  7. CONFIG_IP_MULTICAST is not set
  8. CONFIG_IP_ADVANCED_ROUTER is not set
    CONFIG_IP_FIB_HASH=y
    CONFIG_IP_PNP=y
    CONFIG_IP_PNP_DHCP=y
  9. CONFIG_IP_PNP_BOOTP is not set
  10. CONFIG_IP_PNP_RARP is not set
  11. CONFIG_NET_IPIP is not set
  12. CONFIG_NET_IPGRE is not set
  13. CONFIG_ARPD is not set
  14. CONFIG_SYN_COOKIES is not set
  15. CONFIG_INET_AH is not set
  16. CONFIG_INET_ESP is not set
  17. CONFIG_INET_IPCOMP is not set
  18. CONFIG_INET_XFRM_TUNNEL is not set
  19. CONFIG_INET_TUNNEL is not set
    CONFIG_INET_XFRM_MODE_TRANSPORT=y
    CONFIG_INET_XFRM_MODE_TUNNEL=y
    CONFIG_INET_XFRM_MODE_BEET=y
  20. CONFIG_INET_LRO is not set
    CONFIG_INET_DIAG=y
    CONFIG_INET_TCP_DIAG=y
  21. CONFIG_TCP_CONG_ADVANCED is not set
    CONFIG_TCP_CONG_CUBIC=y
    CONFIG_DEFAULT_TCP_CONG="cubic"
  22. CONFIG_TCP_MD5SIG is not set
  23. CONFIG_IPV6 is not set
  24. CONFIG_NETWORK_SECMARK is not set
  25. CONFIG_NETFILTER is not set
  26. CONFIG_IP_DCCP is not set
  27. CONFIG_IP_SCTP is not set
  28. CONFIG_RDS is not set
  29. CONFIG_TIPC is not set
  30. CONFIG_ATM is not set
  31. CONFIG_BRIDGE is not set
  32. CONFIG_NET_DSA is not set
  33. CONFIG_VLAN_8021Q is not set
  34. CONFIG_DECNET is not set
  35. CONFIG_LLC2 is not set
  36. CONFIG_IPX is not set
  37. CONFIG_ATALK is not set
  38. CONFIG_X25 is not set
  39. CONFIG_LAPB is not set
  40. CONFIG_ECONET is not set
  41. CONFIG_WAN_ROUTER is not set
  42. CONFIG_PHONET is not set
  43. CONFIG_IEEE802154 is not set
  44. CONFIG_NET_SCHED is not set
  45. CONFIG_DCB is not set
  1. Network testing #
  2. CONFIG_NET_PKTGEN is not set
  3. CONFIG_HAMRADIO is not set
  4. CONFIG_CAN is not set
  5. CONFIG_IRDA is not set
  6. CONFIG_BT is not set
  7. CONFIG_AF_RXRPC is not set
  8. CONFIG_WIRELESS is not set
  9. CONFIG_WIMAX is not set
  10. CONFIG_RFKILL is not set
  11. CONFIG_NET_9P is not set
  1. Device Drivers #
  1. Generic Driver Options #
    CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
  2. CONFIG_DEVTMPFS is not set
    CONFIG_STANDALONE=y
    CONFIG_PREVENT_FIRMWARE_BUILD=y
  3. CONFIG_FW_LOADER is not set
  4. CONFIG_DEBUG_DRIVER is not set
  5. CONFIG_DEBUG_DEVRES is not set
  6. CONFIG_SYS_HYPERVISOR is not set
  7. CONFIG_CONNECTOR is not set
    CONFIG_MTD=y
  8. CONFIG_MTD_DEBUG is not set
  9. CONFIG_MTD_TESTS is not set
  10. CONFIG_MTD_CONCAT is not set
    CONFIG_MTD_PARTITIONS=y
  11. CONFIG_MTD_REDBOOT_PARTS is not set
    CONFIG_MTD_CMDLINE_PARTS=y
  12. CONFIG_MTD_AFS_PARTS is not set
  13. CONFIG_MTD_AR7_PARTS is not set
  1. User Modules And Translation Layers #
  2. CONFIG_MTD_CHAR is not set
    CONFIG_MTD_BLKDEVS=y
    CONFIG_MTD_BLOCK=y
  3. CONFIG_FTL is not set
  4. CONFIG_NFTL is not set
  5. CONFIG_INFTL is not set
  6. CONFIG_RFD_FTL is not set
  7. CONFIG_SSFDC is not set
  8. CONFIG_MTD_OOPS is not set
  1. RAM/ROM/Flash chip drivers #
  2. CONFIG_MTD_CFI is not set
  3. CONFIG_MTD_JEDECPROBE is not set
    CONFIG_MTD_MAP_BANK_WIDTH_1=y
    CONFIG_MTD_MAP_BANK_WIDTH_2=y
    CONFIG_MTD_MAP_BANK_WIDTH_4=y
  4. CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
  5. CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
  6. CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
    CONFIG_MTD_CFI_I1=y
    CONFIG_MTD_CFI_I2=y
  7. CONFIG_MTD_CFI_I4 is not set
  8. CONFIG_MTD_CFI_I8 is not set
  9. CONFIG_MTD_RAM is not set
  10. CONFIG_MTD_ROM is not set
  11. CONFIG_MTD_ABSENT is not set
  1. Mapping drivers for chip access #
  2. CONFIG_MTD_COMPLEX_MAPPINGS is not set
  3. CONFIG_MTD_PLATRAM is not set
  1. Self-contained MTD device drivers #
  2. CONFIG_MTD_DATAFLASH is not set
    CONFIG_MTD_M25P80=y
    CONFIG_M25PXX_USE_FAST_READ=y
  3. CONFIG_MTD_SST25L is not set
  4. CONFIG_MTD_SLRAM is not set
  5. CONFIG_MTD_PHRAM is not set
  6. CONFIG_MTD_MTDRAM is not set
  7. CONFIG_MTD_BLOCK2MTD is not set
  1. Disk-On-Chip Device Drivers #
  2. CONFIG_MTD_DOC2000 is not set
  3. CONFIG_MTD_DOC2001 is not set
  4. CONFIG_MTD_DOC2001PLUS is not set
    CONFIG_MTD_NAND=y
  5. CONFIG_MTD_NAND_VERIFY_WRITE is not set
  6. CONFIG_MTD_NAND_ECC_SMC is not set
  7. CONFIG_MTD_NAND_MUSEUM_IDS is not set
  8. CONFIG_MTD_NAND_GPIO is not set
    CONFIG_MTD_NAND_IDS=y
  9. CONFIG_MTD_NAND_DISKONCHIP is not set
  10. CONFIG_MTD_NAND_NANDSIM is not set
  11. CONFIG_MTD_NAND_PLATFORM is not set
  12. CONFIG_MTD_ALAUDA is not set
    CONFIG_MTD_NAND_DAVINCI=y
  13. CONFIG_MTD_ONENAND is not set
  1. LPDDR flash memory drivers #
  2. CONFIG_MTD_LPDDR is not set
  1. UBI - Unsorted block images #
  2. CONFIG_MTD_UBI is not set
  3. CONFIG_PARPORT is not set
    CONFIG_BLK_DEV=y
  4. CONFIG_BLK_DEV_COW_COMMON is not set
    CONFIG_BLK_DEV_LOOP=y
  5. CONFIG_BLK_DEV_CRYPTOLOOP is not set
  1. DRBD disabled because PROC_FS, INET or CONNECTOR not selected #
  2. CONFIG_BLK_DEV_NBD is not set
  3. CONFIG_BLK_DEV_UB is not set
    CONFIG_BLK_DEV_RAM=y
    CONFIG_BLK_DEV_RAM_COUNT=1
    CONFIG_BLK_DEV_RAM_SIZE=32768
  4. CONFIG_BLK_DEV_XIP is not set
  5. CONFIG_CDROM_PKTCDVD is not set
  6. CONFIG_ATA_OVER_ETH is not set
  7. CONFIG_MG_DISK is not set
    CONFIG_MISC_DEVICES=y
  8. CONFIG_AD525X_DPOT is not set
  9. CONFIG_ICS932S401 is not set
  10. CONFIG_ENCLOSURE_SERVICES is not set
  11. CONFIG_ISL29003 is not set
  12. CONFIG_DS1682 is not set
  13. CONFIG_TI_DAC7512 is not set
  14. CONFIG_C2PORT is not set
  1. EEPROM support #
    CONFIG_EEPROM_AT24=y
  2. CONFIG_EEPROM_AT25 is not set
  3. CONFIG_EEPROM_LEGACY is not set
  4. CONFIG_EEPROM_MAX6875 is not set
  5. CONFIG_EEPROM_93CX6 is not set
  6. CONFIG_IWMC3200TOP is not set
    CONFIG_HAVE_IDE=y
  7. CONFIG_IDE is not set
  1. SCSI device support #
  2. CONFIG_RAID_ATTRS is not set
    CONFIG_SCSI=y
    CONFIG_SCSI_DMA=y
    CONFIG_SCSI_TGT=y
  3. CONFIG_SCSI_NETLINK is not set
    CONFIG_SCSI_PROC_FS=y
  1. SCSI support type (disk, tape, CD-ROM) #
    CONFIG_BLK_DEV_SD=y
  2. CONFIG_CHR_DEV_ST is not set
  3. CONFIG_CHR_DEV_OSST is not set
    CONFIG_BLK_DEV_SR=y
  4. CONFIG_BLK_DEV_SR_VENDOR is not set
    CONFIG_CHR_DEV_SG=y
  5. CONFIG_CHR_DEV_SCH is not set
  6. CONFIG_SCSI_MULTI_LUN is not set
    CONFIG_SCSI_CONSTANTS=y
  7. CONFIG_SCSI_LOGGING is not set
  8. CONFIG_SCSI_SCAN_ASYNC is not set
    CONFIG_SCSI_WAIT_SCAN=m
  1. SCSI Transports #
  2. CONFIG_SCSI_SPI_ATTRS is not set
  3. CONFIG_SCSI_FC_ATTRS is not set
  4. CONFIG_SCSI_ISCSI_ATTRS is not set
  5. CONFIG_SCSI_SAS_LIBSAS is not set
  6. CONFIG_SCSI_SRP_ATTRS is not set
    CONFIG_SCSI_LOWLEVEL=y
  7. CONFIG_ISCSI_TCP is not set
  8. CONFIG_LIBFC is not set
  9. CONFIG_LIBFCOE is not set
  10. CONFIG_SCSI_DEBUG is not set
  11. CONFIG_SCSI_DH is not set
  12. CONFIG_SCSI_OSD_INITIATOR is not set
  13. CONFIG_ATA is not set
  14. CONFIG_MD is not set
    CONFIG_NETDEVICES=y
  15. CONFIG_DUMMY is not set
  16. CONFIG_BONDING is not set
  17. CONFIG_MACVLAN is not set
  18. CONFIG_EQUALIZER is not set
  19. CONFIG_TUN is not set
  20. CONFIG_VETH is not set
    CONFIG_PHYLIB=y
  1. MII PHY device drivers #
  2. CONFIG_MARVELL_PHY is not set
  3. CONFIG_DAVICOM_PHY is not set
  4. CONFIG_QSEMI_PHY is not set
    CONFIG_LXT_PHY=y
  5. CONFIG_CICADA_PHY is not set
  6. CONFIG_VITESSE_PHY is not set
  7. CONFIG_SMSC_PHY is not set
  8. CONFIG_BROADCOM_PHY is not set
  9. CONFIG_ICPLUS_PHY is not set
  10. CONFIG_REALTEK_PHY is not set
  11. CONFIG_NATIONAL_PHY is not set
  12. CONFIG_STE10XP is not set
    CONFIG_LSI_ET1011C_PHY=y
  13. CONFIG_FIXED_PHY is not set
  14. CONFIG_MDIO_BITBANG is not set
    CONFIG_NET_ETHERNET=y
    CONFIG_MII=y
  15. CONFIG_AX88796 is not set
  16. CONFIG_SMC91X is not set
    CONFIG_TI_DAVINCI_EMAC=y
  17. CONFIG_DM9000 is not set
  18. CONFIG_ENC28J60 is not set
  19. CONFIG_ETHOC is not set
  20. CONFIG_SMC911X is not set
  21. CONFIG_SMSC911X is not set
  22. CONFIG_DNET is not set
  23. CONFIG_IBM_NEW_EMAC_ZMII is not set
  24. CONFIG_IBM_NEW_EMAC_RGMII is not set
  25. CONFIG_IBM_NEW_EMAC_TAH is not set
  26. CONFIG_IBM_NEW_EMAC_EMAC4 is not set
  27. CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set
  28. CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set
  29. CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set
  30. CONFIG_B44 is not set
  31. CONFIG_KS8842 is not set
  32. CONFIG_KS8851 is not set
  33. CONFIG_KS8851_MLL is not set
  34. CONFIG_NETDEV_1000 is not set
  35. CONFIG_NETDEV_10000 is not set
  36. CONFIG_WLAN is not set
  1. Enable WiMAX (Networking options) to see the WiMAX drivers #
  1. USB Network Adapters #
  2. CONFIG_USB_CATC is not set
  3. CONFIG_USB_KAWETH is not set
  4. CONFIG_USB_PEGASUS is not set
  5. CONFIG_USB_RTL8150 is not set
  6. CONFIG_USB_USBNET is not set
  7. CONFIG_WAN is not set
  8. CONFIG_PPP is not set
  9. CONFIG_SLIP is not set
  10. CONFIG_NETCONSOLE is not set
  11. CONFIG_NETPOLL is not set
  12. CONFIG_NET_POLL_CONTROLLER is not set
  13. CONFIG_ISDN is not set
  14. CONFIG_PHONE is not set
  1. Input device support #
    CONFIG_INPUT=y
  2. CONFIG_INPUT_FF_MEMLESS is not set
  3. CONFIG_INPUT_POLLDEV is not set
  4. CONFIG_INPUT_SPARSEKMAP is not set
  1. Userland interfaces #
  2. CONFIG_INPUT_MOUSEDEV is not set
  3. CONFIG_INPUT_JOYDEV is not set
  4. CONFIG_INPUT_EVDEV is not set
  5. CONFIG_INPUT_EVBUG is not set
  1. Input Device Drivers #
  2. CONFIG_INPUT_KEYBOARD is not set
  3. CONFIG_INPUT_MOUSE is not set
  4. CONFIG_INPUT_JOYSTICK is not set
  5. CONFIG_INPUT_TABLET is not set
  6. CONFIG_INPUT_TOUCHSCREEN is not set
  7. CONFIG_INPUT_MISC is not set
  1. Hardware I/O ports #
  2. CONFIG_SERIO is not set
  3. CONFIG_GAMEPORT is not set
  1. Character devices #
    CONFIG_VT=y
    CONFIG_CONSOLE_TRANSLATIONS=y
    CONFIG_VT_CONSOLE=y
    CONFIG_HW_CONSOLE=y
  2. CONFIG_VT_HW_CONSOLE_BINDING is not set
    CONFIG_DEVKMEM=y
  3. CONFIG_SERIAL_NONSTANDARD is not set
  1. Serial drivers #
    CONFIG_SERIAL_8250=y
    CONFIG_SERIAL_8250_CONSOLE=y
    CONFIG_SERIAL_8250_NR_UARTS=3
    CONFIG_SERIAL_8250_RUNTIME_UARTS=3
  2. CONFIG_SERIAL_8250_EXTENDED is not set
  1. Non-8250 serial port support #
  2. CONFIG_SERIAL_MAX3100 is not set
    CONFIG_SERIAL_CORE=y
    CONFIG_SERIAL_CORE_CONSOLE=y
  3. CONFIG_SERIAL_TIMBERDALE is not set
    CONFIG_UNIX98_PTYS=y
  4. CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
    CONFIG_LEGACY_PTYS=y
    CONFIG_LEGACY_PTY_COUNT=256
  5. CONFIG_IPMI_HANDLER is not set
  6. CONFIG_HW_RANDOM is not set
  7. CONFIG_R3964 is not set
  8. CONFIG_RAW_DRIVER is not set
  9. CONFIG_TCG_TPM is not set
    CONFIG_I2C=y
    CONFIG_I2C_BOARDINFO=y
    CONFIG_I2C_COMPAT=y
    CONFIG_I2C_CHARDEV=y
    CONFIG_I2C_HELPER_AUTO=y
  1. I2C Hardware Bus support #
  1. I2C system bus drivers (mostly embedded / system-on-chip) #
    CONFIG_I2C_DAVINCI=y
  2. CONFIG_I2C_DESIGNWARE is not set
  3. CONFIG_I2C_GPIO is not set
  4. CONFIG_I2C_OCORES is not set
  5. CONFIG_I2C_SIMTEC is not set
  6. CONFIG_I2C_XILINX is not set
  1. External I2C/SMBus adapter drivers #
  2. CONFIG_I2C_PARPORT_LIGHT is not set
  3. CONFIG_I2C_TAOS_EVM is not set
  4. CONFIG_I2C_TINY_USB is not set
  1. Other I2C/SMBus bus drivers #
  2. CONFIG_I2C_PCA_PLATFORM is not set
  3. CONFIG_I2C_STUB is not set
  1. Miscellaneous I2C Chip support #
  2. CONFIG_SENSORS_TSL2550 is not set
  3. CONFIG_I2C_DEBUG_CORE is not set
  4. CONFIG_I2C_DEBUG_ALGO is not set
  5. CONFIG_I2C_DEBUG_BUS is not set
  6. CONFIG_I2C_DEBUG_CHIP is not set
    CONFIG_SPI=y
    CONFIG_SPI_DEBUG=y
    CONFIG_SPI_MASTER=y
  1. SPI Master Controller Drivers #
    CONFIG_SPI_DAVINCI=y
    CONFIG_SPI_BITBANG=y
  2. CONFIG_SPI_GPIO is not set
  3. CONFIG_SPI_XILINX is not set
  4. CONFIG_SPI_DESIGNWARE is not set
  1. SPI Protocol Masters #
  2. CONFIG_SPI_SPIDEV is not set
  3. CONFIG_SPI_TLE62X0 is not set
  1. PPS support #
  2. CONFIG_PPS is not set
    CONFIG_ARCH_REQUIRE_GPIOLIB=y
    CONFIG_GPIOLIB=y
  3. CONFIG_DEBUG_GPIO is not set
    CONFIG_GPIO_SYSFS=y
  1. Memory mapped GPIO expanders: #
  2. CONFIG_GPIO_IT8761E is not set
  1. I2C GPIO expanders: #
  2. CONFIG_GPIO_MAX7300 is not set
  3. CONFIG_GPIO_MAX732X is not set
    CONFIG_GPIO_PCA953X=y
  4. CONFIG_GPIO_PCA953X_IRQ is not set
    CONFIG_GPIO_PCF857X=y
  5. CONFIG_GPIO_ADP5588 is not set
  1. PCI GPIO expanders: #
  1. SPI GPIO expanders: #
  2. CONFIG_GPIO_MAX7301 is not set
  3. CONFIG_GPIO_MCP23S08 is not set
  4. CONFIG_GPIO_MC33880 is not set
  1. AC97 GPIO expanders: #
  2. CONFIG_W1 is not set
  3. CONFIG_POWER_SUPPLY is not set
  4. CONFIG_HWMON is not set
  5. CONFIG_THERMAL is not set
    CONFIG_WATCHDOG=y
  6. CONFIG_WATCHDOG_NOWAYOUT is not set
  1. Watchdog Device Drivers #
  2. CONFIG_SOFT_WATCHDOG is not set
  3. CONFIG_MAX63XX_WATCHDOG is not set
  4. CONFIG_DAVINCI_WATCHDOG is not set
  1. USB-based Watchdog Cards #
  2. CONFIG_USBPCWATCHDOG is not set
    CONFIG_SSB_POSSIBLE=y
  1. Sonics Silicon Backplane #
  2. CONFIG_SSB is not set
  1. Multifunction device drivers #
  2. CONFIG_MFD_CORE is not set
  3. CONFIG_MFD_88PM860X is not set
  4. CONFIG_MFD_SM501 is not set
  5. CONFIG_MFD_ASIC3 is not set
  6. CONFIG_HTC_EGPIO is not set
  7. CONFIG_HTC_PASIC3 is not set
  8. CONFIG_HTC_I2CPLD is not set
  9. CONFIG_TPS65010 is not set
  10. CONFIG_TPS6507x is not set
  11. CONFIG_TWL4030_CORE is not set
  12. CONFIG_MFD_TMIO is not set
  13. CONFIG_MFD_T7L66XB is not set
  14. CONFIG_MFD_TC6387XB is not set
  15. CONFIG_MFD_TC6393XB is not set
  16. CONFIG_PMIC_DA903X is not set
  17. CONFIG_PMIC_ADP5520 is not set
  18. CONFIG_MFD_MAX8925 is not set
  19. CONFIG_MFD_WM8400 is not set
  20. CONFIG_MFD_WM831X is not set
  21. CONFIG_MFD_WM8350_I2C is not set
  22. CONFIG_MFD_WM8994 is not set
  23. CONFIG_MFD_PCF50633 is not set
  24. CONFIG_MFD_MC13783 is not set
  25. CONFIG_AB3100_CORE is not set
  26. CONFIG_EZX_PCAP is not set
  27. CONFIG_AB4500_CORE is not set
    CONFIG_REGULATOR=y
  28. CONFIG_REGULATOR_DEBUG is not set
  29. CONFIG_REGULATOR_DUMMY is not set
  30. CONFIG_REGULATOR_FIXED_VOLTAGE is not set
  31. CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
  32. CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
  33. CONFIG_REGULATOR_BQ24022 is not set
  34. CONFIG_REGULATOR_MAX1586 is not set
  35. CONFIG_REGULATOR_MAX8649 is not set
  36. CONFIG_REGULATOR_MAX8660 is not set
  37. CONFIG_REGULATOR_LP3971 is not set
    CONFIG_REGULATOR_TPS65023=y
  38. CONFIG_REGULATOR_TPS6507X is not set
  39. CONFIG_MEDIA_SUPPORT is not set
  1. Graphics support #
  2. CONFIG_VGASTATE is not set
  3. CONFIG_VIDEO_OUTPUT_CONTROL is not set
  4. CONFIG_FB is not set
  5. CONFIG_BACKLIGHT_LCD_SUPPORT is not set
  1. Display device support #
  2. CONFIG_DISPLAY_SUPPORT is not set
  1. Console display driver support #
  2. CONFIG_VGA_CONSOLE is not set
    CONFIG_DUMMY_CONSOLE=y
  3. CONFIG_SOUND is not set
  4. CONFIG_HID_SUPPORT is not set
    CONFIG_USB_SUPPORT=y
    CONFIG_USB_ARCH_HAS_HCD=y
    CONFIG_USB_ARCH_HAS_OHCI=y
  5. CONFIG_USB_ARCH_HAS_EHCI is not set
    CONFIG_USB=y
  6. CONFIG_USB_DEBUG is not set
  7. CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
  1. Miscellaneous USB options #
    CONFIG_USB_DEVICEFS=y
    CONFIG_USB_DEVICE_CLASS=y
  2. CONFIG_USB_DYNAMIC_MINORS is not set
  3. CONFIG_USB_OTG is not set
  4. CONFIG_USB_OTG_WHITELIST is not set
  5. CONFIG_USB_OTG_BLACKLIST_HUB is not set
  6. CONFIG_USB_MON is not set
  7. CONFIG_USB_WUSB is not set
  8. CONFIG_USB_WUSB_CBAF is not set
  1. USB Host Controller Drivers #
  2. CONFIG_USB_C67X00_HCD is not set
  3. CONFIG_USB_OXU210HP_HCD is not set
  4. CONFIG_USB_ISP116X_HCD is not set
  5. CONFIG_USB_ISP1760_HCD is not set
  6. CONFIG_USB_ISP1362_HCD is not set
    CONFIG_USB_OHCI_HCD=y
  7. CONFIG_USB_OHCI_BIG_ENDIAN_DESC is not set
  8. CONFIG_USB_OHCI_BIG_ENDIAN_MMIO is not set
    CONFIG_USB_OHCI_LITTLE_ENDIAN=y
  9. CONFIG_USB_SL811_HCD is not set
  10. CONFIG_USB_R8A66597_HCD is not set
  11. CONFIG_USB_HWA_HCD is not set
    CONFIG_USB_MUSB_HDRC=y
    CONFIG_USB_MUSB_SOC=y
  1. DA830/OMAP-L137 USB support #
    CONFIG_USB_MUSB_HOST=y
  2. CONFIG_USB_MUSB_PERIPHERAL is not set
  3. CONFIG_USB_MUSB_DUAL_ROLE is not set
  4. CONFIG_USB_MUSB_OTG is not set
    CONFIG_USB_MUSB_HDRC_HCD=y
  5. CONFIG_MUSB_PIO_ONLY is not set
  6. CONFIG_USB_INVENTRA_DMA is not set
  7. CONFIG_USB_TI_CPPI_DMA is not set
    CONFIG_USB_TI_CPPI41_DMA=y
  8. CONFIG_USB_MUSB_DEBUG is not set
  1. USB Device Class drivers #
  2. CONFIG_USB_ACM is not set
  3. CONFIG_USB_PRINTER is not set
  4. CONFIG_USB_WDM is not set
  5. CONFIG_USB_TMC is not set
  1. NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may #
  1. also be needed; see USB_STORAGE Help for more info #
    CONFIG_USB_STORAGE=y
  2. CONFIG_USB_STORAGE_DEBUG is not set
  3. CONFIG_USB_STORAGE_DATAFAB is not set
  4. CONFIG_USB_STORAGE_FREECOM is not set
  5. CONFIG_USB_STORAGE_ISD200 is not set
  6. CONFIG_USB_STORAGE_USBAT is not set
  7. CONFIG_USB_STORAGE_SDDR09 is not set
  8. CONFIG_USB_STORAGE_SDDR55 is not set
  9. CONFIG_USB_STORAGE_JUMPSHOT is not set
  10. CONFIG_USB_STORAGE_ALAUDA is not set
  11. CONFIG_USB_STORAGE_ONETOUCH is not set
  12. CONFIG_USB_STORAGE_KARMA is not set
  13. CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
  14. CONFIG_USB_LIBUSUAL is not set
  1. USB Imaging devices #
  2. CONFIG_USB_MDC800 is not set
  3. CONFIG_USB_MICROTEK is not set
  1. USB port drivers #
  2. CONFIG_USB_SERIAL is not set
  1. USB Miscellaneous drivers #
  2. CONFIG_USB_EMI62 is not set
  3. CONFIG_USB_EMI26 is not set
  4. CONFIG_USB_ADUTUX is not set
  5. CONFIG_USB_SEVSEG is not set
  6. CONFIG_USB_RIO500 is not set
  7. CONFIG_USB_LEGOTOWER is not set
  8. CONFIG_USB_LCD is not set
  9. CONFIG_USB_LED is not set
  10. CONFIG_USB_CYPRESS_CY7C63 is not set
  11. CONFIG_USB_CYTHERM is not set
  12. CONFIG_USB_IDMOUSE is not set
  13. CONFIG_USB_FTDI_ELAN is not set
  14. CONFIG_USB_APPLEDISPLAY is not set
  15. CONFIG_USB_SISUSBVGA is not set
  16. CONFIG_USB_LD is not set
  17. CONFIG_USB_TRANCEVIBRATOR is not set
  18. CONFIG_USB_IOWARRIOR is not set
  19. CONFIG_USB_TEST is not set
  20. CONFIG_USB_ISIGHTFW is not set
  21. CONFIG_USB_GADGET is not set
  1. OTG and related infrastructure #
    CONFIG_USB_OTG_UTILS=y
  2. CONFIG_USB_GPIO_VBUS is not set
  3. CONFIG_USB_ULPI is not set
    CONFIG_NOP_USB_XCEIV=y
    CONFIG_MMC=y
  4. CONFIG_MMC_DEBUG is not set
  5. CONFIG_MMC_UNSAFE_RESUME is not set
  1. MMC/SD/SDIO Card Drivers #
    CONFIG_MMC_BLOCK=y
    CONFIG_MMC_BLOCK_BOUNCE=y
  2. CONFIG_SDIO_UART is not set
  3. CONFIG_MMC_TEST is not set
  1. MMC/SD/SDIO Host Controller Drivers #
  2. CONFIG_MMC_SDHCI is not set
    CONFIG_MMC_DAVINCI=y
  3. CONFIG_MMC_SPI is not set
  4. CONFIG_MEMSTICK is not set
  5. CONFIG_NEW_LEDS is not set
  6. CONFIG_ACCESSIBILITY is not set
    CONFIG_RTC_LIB=y
    CONFIG_RTC_CLASS=y
    CONFIG_RTC_HCTOSYS=y
    CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
  7. CONFIG_RTC_DEBUG is not set
  1. RTC interfaces #
    CONFIG_RTC_INTF_SYSFS=y
    CONFIG_RTC_INTF_PROC=y
    CONFIG_RTC_INTF_DEV=y
  2. CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
  3. CONFIG_RTC_DRV_TEST is not set
  1. I2C RTC drivers #
  2. CONFIG_RTC_DRV_DS1307 is not set
  3. CONFIG_RTC_DRV_DS1374 is not set
  4. CONFIG_RTC_DRV_DS1672 is not set
  5. CONFIG_RTC_DRV_MAX6900 is not set
  6. CONFIG_RTC_DRV_RS5C372 is not set
  7. CONFIG_RTC_DRV_ISL1208 is not set
  8. CONFIG_RTC_DRV_X1205 is not set
  9. CONFIG_RTC_DRV_PCF8563 is not set
  10. CONFIG_RTC_DRV_PCF8583 is not set
  11. CONFIG_RTC_DRV_M41T80 is not set
  12. CONFIG_RTC_DRV_BQ32K is not set
  13. CONFIG_RTC_DRV_S35390A is not set
  14. CONFIG_RTC_DRV_FM3130 is not set
  15. CONFIG_RTC_DRV_RX8581 is not set
  16. CONFIG_RTC_DRV_RX8025 is not set
  1. SPI RTC drivers #
  2. CONFIG_RTC_DRV_M41T94 is not set
  3. CONFIG_RTC_DRV_DS1305 is not set
  4. CONFIG_RTC_DRV_DS1390 is not set
  5. CONFIG_RTC_DRV_MAX6902 is not set
  6. CONFIG_RTC_DRV_R9701 is not set
  7. CONFIG_RTC_DRV_RS5C348 is not set
  8. CONFIG_RTC_DRV_DS3234 is not set
  9. CONFIG_RTC_DRV_PCF2123 is not set
  1. Platform RTC drivers #
  2. CONFIG_RTC_DRV_CMOS is not set
  3. CONFIG_RTC_DRV_DS1286 is not set
  4. CONFIG_RTC_DRV_DS1511 is not set
  5. CONFIG_RTC_DRV_DS1553 is not set
  6. CONFIG_RTC_DRV_DS1742 is not set
  7. CONFIG_RTC_DRV_STK17TA8 is not set
  8. CONFIG_RTC_DRV_M48T86 is not set
  9. CONFIG_RTC_DRV_M48T35 is not set
  10. CONFIG_RTC_DRV_M48T59 is not set
  11. CONFIG_RTC_DRV_MSM6242 is not set
  12. CONFIG_RTC_DRV_BQ4802 is not set
  13. CONFIG_RTC_DRV_RP5C01 is not set
  14. CONFIG_RTC_DRV_V3020 is not set
  1. on-CPU RTC drivers #
    CONFIG_RTC_DRV_OMAP=y
  2. CONFIG_DMADEVICES is not set
  3. CONFIG_AUXDISPLAY is not set
  4. CONFIG_UIO is not set
  1. TI VLYNQ #
  2. CONFIG_STAGING is not set
  1. File systems #
    CONFIG_EXT2_FS=y
  2. CONFIG_EXT2_FS_XATTR is not set
  3. CONFIG_EXT2_FS_XIP is not set
  4. CONFIG_EXT3_FS is not set
  5. CONFIG_EXT4_FS is not set
  6. CONFIG_REISERFS_FS is not set
  7. CONFIG_JFS_FS is not set
  8. CONFIG_FS_POSIX_ACL is not set
  9. CONFIG_XFS_FS is not set
  10. CONFIG_GFS2_FS is not set
  11. CONFIG_OCFS2_FS is not set
  12. CONFIG_BTRFS_FS is not set
  13. CONFIG_NILFS2_FS is not set
    CONFIG_FILE_LOCKING=y
    CONFIG_FSNOTIFY=y
    CONFIG_DNOTIFY=y
  14. CONFIG_INOTIFY is not set
    CONFIG_INOTIFY_USER=y
  15. CONFIG_QUOTA is not set
  16. CONFIG_AUTOFS_FS is not set
  17. CONFIG_AUTOFS4_FS is not set
  18. CONFIG_FUSE_FS is not set
  1. Caches #
  2. CONFIG_FSCACHE is not set
  1. CD-ROM/DVD Filesystems #
  2. CONFIG_ISO9660_FS is not set
  3. CONFIG_UDF_FS is not set
  1. DOS/FAT/NT Filesystems #
    CONFIG_FAT_FS=y
    CONFIG_MSDOS_FS=y
    CONFIG_VFAT_FS=y
    CONFIG_FAT_DEFAULT_CODEPAGE=437
    CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
  2. CONFIG_NTFS_FS is not set
  1. Pseudo filesystems #
    CONFIG_PROC_FS=y
    CONFIG_PROC_SYSCTL=y
    CONFIG_PROC_PAGE_MONITOR=y
    CONFIG_SYSFS=y
    CONFIG_TMPFS=y
  2. CONFIG_TMPFS_POSIX_ACL is not set
  3. CONFIG_HUGETLB_PAGE is not set
  4. CONFIG_CONFIGFS_FS is not set
    CONFIG_MISC_FILESYSTEMS=y
  5. CONFIG_ADFS_FS is not set
  6. CONFIG_AFFS_FS is not set
  7. CONFIG_HFS_FS is not set
  8. CONFIG_HFSPLUS_FS is not set
  9. CONFIG_BEFS_FS is not set
  10. CONFIG_BFS_FS is not set
  11. CONFIG_EFS_FS is not set
    CONFIG_JFFS2_FS=y
    CONFIG_JFFS2_FS_DEBUG=0
    CONFIG_JFFS2_FS_WRITEBUFFER=y
  12. CONFIG_JFFS2_FS_WBUF_VERIFY is not set
  13. CONFIG_JFFS2_SUMMARY is not set
  14. CONFIG_JFFS2_FS_XATTR is not set
  15. CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
    CONFIG_JFFS2_ZLIB=y
  16. CONFIG_JFFS2_LZO is not set
    CONFIG_JFFS2_RTIME=y
  17. CONFIG_JFFS2_RUBIN is not set
  18. CONFIG_LOGFS is not set
    CONFIG_CRAMFS=y
  19. CONFIG_SQUASHFS is not set
  20. CONFIG_VXFS_FS is not set
  21. CONFIG_MINIX_FS is not set
  22. CONFIG_OMFS_FS is not set
  23. CONFIG_HPFS_FS is not set
  24. CONFIG_QNX4FS_FS is not set
  25. CONFIG_ROMFS_FS is not set
  26. CONFIG_SYSV_FS is not set
  27. CONFIG_UFS_FS is not set
  28. CONFIG_NETWORK_FILESYSTEMS is not set
  1. Partition Types #
    CONFIG_PARTITION_ADVANCED=y
  2. CONFIG_ACORN_PARTITION is not set
  3. CONFIG_OSF_PARTITION is not set
  4. CONFIG_AMIGA_PARTITION is not set
  5. CONFIG_ATARI_PARTITION is not set
  6. CONFIG_MAC_PARTITION is not set
    CONFIG_MSDOS_PARTITION=y
  7. CONFIG_BSD_DISKLABEL is not set
  8. CONFIG_MINIX_SUBPARTITION is not set
  9. CONFIG_SOLARIS_X86_PARTITION is not set
  10. CONFIG_UNIXWARE_DISKLABEL is not set
  11. CONFIG_LDM_PARTITION is not set
  12. CONFIG_SGI_PARTITION is not set
  13. CONFIG_ULTRIX_PARTITION is not set
  14. CONFIG_SUN_PARTITION is not set
  15. CONFIG_KARMA_PARTITION is not set
  16. CONFIG_EFI_PARTITION is not set
  17. CONFIG_SYSV68_PARTITION is not set
    CONFIG_NLS=y
    CONFIG_NLS_DEFAULT="iso8859-1"
    CONFIG_NLS_CODEPAGE_437=y
  18. CONFIG_NLS_CODEPAGE_737 is not set
  19. CONFIG_NLS_CODEPAGE_775 is not set
  20. CONFIG_NLS_CODEPAGE_850 is not set
  21. CONFIG_NLS_CODEPAGE_852 is not set
  22. CONFIG_NLS_CODEPAGE_855 is not set
  23. CONFIG_NLS_CODEPAGE_857 is not set
  24. CONFIG_NLS_CODEPAGE_860 is not set
  25. CONFIG_NLS_CODEPAGE_861 is not set
  26. CONFIG_NLS_CODEPAGE_862 is not set
  27. CONFIG_NLS_CODEPAGE_863 is not set
  28. CONFIG_NLS_CODEPAGE_864 is not set
  29. CONFIG_NLS_CODEPAGE_865 is not set
  30. CONFIG_NLS_CODEPAGE_866 is not set
  31. CONFIG_NLS_CODEPAGE_869 is not set
  32. CONFIG_NLS_CODEPAGE_936 is not set
  33. CONFIG_NLS_CODEPAGE_950 is not set
  34. CONFIG_NLS_CODEPAGE_932 is not set
  35. CONFIG_NLS_CODEPAGE_949 is not set
  36. CONFIG_NLS_CODEPAGE_874 is not set
  37. CONFIG_NLS_ISO8859_8 is not set
  38. CONFIG_NLS_CODEPAGE_1250 is not set
  39. CONFIG_NLS_CODEPAGE_1251 is not set
    CONFIG_NLS_ASCII=m
    CONFIG_NLS_ISO8859_1=y
  40. CONFIG_NLS_ISO8859_2 is not set
  41. CONFIG_NLS_ISO8859_3 is not set
  42. CONFIG_NLS_ISO8859_4 is not set
  43. CONFIG_NLS_ISO8859_5 is not set
  44. CONFIG_NLS_ISO8859_6 is not set
  45. CONFIG_NLS_ISO8859_7 is not set
  46. CONFIG_NLS_ISO8859_9 is not set
  47. CONFIG_NLS_ISO8859_13 is not set
  48. CONFIG_NLS_ISO8859_14 is not set
  49. CONFIG_NLS_ISO8859_15 is not set
  50. CONFIG_NLS_KOI8_R is not set
  51. CONFIG_NLS_KOI8_U is not set
    CONFIG_NLS_UTF8=m
  52. CONFIG_DLM is not set
  1. Kernel hacking #
  2. CONFIG_PRINTK_TIME is not set
    CONFIG_ENABLE_WARN_DEPRECATED=y
    CONFIG_ENABLE_MUST_CHECK=y
    CONFIG_FRAME_WARN=1024
  3. CONFIG_MAGIC_SYSRQ is not set
  4. CONFIG_STRIP_ASM_SYMS is not set
  5. CONFIG_UNUSED_SYMBOLS is not set
    CONFIG_DEBUG_FS=y
  6. CONFIG_HEADERS_CHECK is not set
    CONFIG_DEBUG_KERNEL=y
  7. CONFIG_DEBUG_SHIRQ is not set
    CONFIG_DETECT_SOFTLOCKUP=y
  8. CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC is not set
    CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC_VALUE=0
    CONFIG_DETECT_HUNG_TASK=y
  9. CONFIG_BOOTPARAM_HUNG_TASK_PANIC is not set
    CONFIG_BOOTPARAM_HUNG_TASK_PANIC_VALUE=0
    CONFIG_SCHED_DEBUG=y
  10. CONFIG_SCHEDSTATS is not set
    CONFIG_TIMER_STATS=y
  11. CONFIG_DEBUG_OBJECTS is not set
  12. CONFIG_DEBUG_SLAB is not set
  13. CONFIG_DEBUG_KMEMLEAK is not set
    CONFIG_DEBUG_PREEMPT=y
    CONFIG_DEBUG_RT_MUTEXES=y
    CONFIG_DEBUG_PI_LIST=y
  14. CONFIG_RT_MUTEX_TESTER is not set
  15. CONFIG_DEBUG_SPINLOCK is not set
  16. CONFIG_DEBUG_MUTEXES is not set
  17. CONFIG_DEBUG_LOCK_ALLOC is not set
  18. CONFIG_PROVE_LOCKING is not set
  19. CONFIG_LOCK_STAT is not set
  20. CONFIG_DEBUG_SPINLOCK_SLEEP is not set
  21. CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
  22. CONFIG_DEBUG_KOBJECT is not set
    CONFIG_DEBUG_BUGVERBOSE=y
  23. CONFIG_DEBUG_INFO is not set
  24. CONFIG_DEBUG_VM is not set
  25. CONFIG_DEBUG_WRITECOUNT is not set
  26. CONFIG_DEBUG_MEMORY_INIT is not set
  27. CONFIG_DEBUG_LIST is not set
  28. CONFIG_DEBUG_SG is not set
  29. CONFIG_DEBUG_NOTIFIERS is not set
  30. CONFIG_DEBUG_CREDENTIALS is not set
  31. CONFIG_BOOT_PRINTK_DELAY is not set
  32. CONFIG_RCU_TORTURE_TEST is not set
  33. CONFIG_RCU_CPU_STALL_DETECTOR is not set
  34. CONFIG_BACKTRACE_SELF_TEST is not set
  35. CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
  36. CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
  37. CONFIG_LKDTM is not set
  38. CONFIG_FAULT_INJECTION is not set
  39. CONFIG_LATENCYTOP is not set
  40. CONFIG_SYSCTL_SYSCALL_CHECK is not set
  41. CONFIG_PAGE_POISONING is not set
    CONFIG_HAVE_FUNCTION_TRACER=y
    CONFIG_TRACING_SUPPORT=y
    CONFIG_FTRACE=y
  42. CONFIG_FUNCTION_TRACER is not set
  43. CONFIG_IRQSOFF_TRACER is not set
  44. CONFIG_PREEMPT_TRACER is not set
  45. CONFIG_SCHED_TRACER is not set
  46. CONFIG_ENABLE_DEFAULT_TRACERS is not set
  47. CONFIG_BOOT_TRACER is not set
    CONFIG_BRANCH_PROFILE_NONE=y
  48. CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
  49. CONFIG_PROFILE_ALL_BRANCHES is not set
  50. CONFIG_STACK_TRACER is not set
  51. CONFIG_KMEMTRACE is not set
  52. CONFIG_WORKQUEUE_TRACER is not set
  53. CONFIG_BLK_DEV_IO_TRACE is not set
  54. CONFIG_DYNAMIC_DEBUG is not set
  55. CONFIG_SAMPLES is not set
    CONFIG_HAVE_ARCH_KGDB=y
  56. CONFIG_KGDB is not set
    CONFIG_ARM_UNWIND=y
    CONFIG_DEBUG_USER=y
    CONFIG_DEBUG_ERRORS=y
  57. CONFIG_DEBUG_STACK_USAGE is not set
  58. CONFIG_DEBUG_LL is not set
  59. CONFIG_OC_ETM is not set
  1. Security options #
  2. CONFIG_KEYS is not set
  3. CONFIG_SECURITY is not set
  4. CONFIG_SECURITYFS is not set
  5. CONFIG_DEFAULT_SECURITY_SELINUX is not set
  6. CONFIG_DEFAULT_SECURITY_SMACK is not set
  7. CONFIG_DEFAULT_SECURITY_TOMOYO is not set
    CONFIG_DEFAULT_SECURITY_DAC=y
    CONFIG_DEFAULT_SECURITY=""
    CONFIG_CRYPTO=y
  1. Crypto core or helper #
  2. CONFIG_CRYPTO_MANAGER is not set
  3. CONFIG_CRYPTO_MANAGER2 is not set
  4. CONFIG_CRYPTO_GF128MUL is not set
  5. CONFIG_CRYPTO_NULL is not set
  6. CONFIG_CRYPTO_CRYPTD is not set
  7. CONFIG_CRYPTO_AUTHENC is not set
  8. CONFIG_CRYPTO_TEST is not set
  1. Authenticated Encryption with Associated Data #
  2. CONFIG_CRYPTO_CCM is not set
  3. CONFIG_CRYPTO_GCM is not set
  4. CONFIG_CRYPTO_SEQIV is not set
  1. Block modes #
  2. CONFIG_CRYPTO_CBC is not set
  3. CONFIG_CRYPTO_CTR is not set
  4. CONFIG_CRYPTO_CTS is not set
  5. CONFIG_CRYPTO_ECB is not set
  6. CONFIG_CRYPTO_LRW is not set
  7. CONFIG_CRYPTO_PCBC is not set
  8. CONFIG_CRYPTO_XTS is not set
  1. Hash modes #
  2. CONFIG_CRYPTO_HMAC is not set
  3. CONFIG_CRYPTO_XCBC is not set
  4. CONFIG_CRYPTO_VMAC is not set
  1. Digest #
  2. CONFIG_CRYPTO_CRC32C is not set
  3. CONFIG_CRYPTO_GHASH is not set
  4. CONFIG_CRYPTO_MD4 is not set
  5. CONFIG_CRYPTO_MD5 is not set
  6. CONFIG_CRYPTO_MICHAEL_MIC is not set
  7. CONFIG_CRYPTO_RMD128 is not set
  8. CONFIG_CRYPTO_RMD160 is not set
  9. CONFIG_CRYPTO_RMD256 is not set
  10. CONFIG_CRYPTO_RMD320 is not set
  11. CONFIG_CRYPTO_SHA1 is not set
  12. CONFIG_CRYPTO_SHA256 is not set
  13. CONFIG_CRYPTO_SHA512 is not set
  14. CONFIG_CRYPTO_TGR192 is not set
  15. CONFIG_CRYPTO_WP512 is not set
  1. Ciphers #
  2. CONFIG_CRYPTO_AES is not set
  3. CONFIG_CRYPTO_ANUBIS is not set
  4. CONFIG_CRYPTO_ARC4 is not set
  5. CONFIG_CRYPTO_BLOWFISH is not set
  6. CONFIG_CRYPTO_CAMELLIA is not set
  7. CONFIG_CRYPTO_CAST5 is not set
  8. CONFIG_CRYPTO_CAST6 is not set
  9. CONFIG_CRYPTO_DES is not set
  10. CONFIG_CRYPTO_FCRYPT is not set
  11. CONFIG_CRYPTO_KHAZAD is not set
  12. CONFIG_CRYPTO_SALSA20 is not set
  13. CONFIG_CRYPTO_SEED is not set
  14. CONFIG_CRYPTO_SERPENT is not set
  15. CONFIG_CRYPTO_TEA is not set
  16. CONFIG_CRYPTO_TWOFISH is not set
  1. Compression #
  2. CONFIG_CRYPTO_DEFLATE is not set
  3. CONFIG_CRYPTO_ZLIB is not set
  4. CONFIG_CRYPTO_LZO is not set
  1. Random Number Generation #
  2. CONFIG_CRYPTO_ANSI_CPRNG is not set
  3. CONFIG_CRYPTO_HW is not set
  4. CONFIG_BINARY_PRINTF is not set
  1. Library routines #
    CONFIG_BITREVERSE=y
    CONFIG_GENERIC_FIND_LAST_BIT=y
  2. CONFIG_CRC_CCITT is not set
  3. CONFIG_CRC16 is not set
  4. CONFIG_CRC_T10DIF is not set
  5. CONFIG_CRC_ITU_T is not set
    CONFIG_CRC32=y
  6. CONFIG_CRC7 is not set
  7. CONFIG_LIBCRC32C is not set
    CONFIG_ZLIB_INFLATE=y
    CONFIG_ZLIB_DEFLATE=y
    CONFIG_DECOMPRESS_GZIP=y
    CONFIG_GENERIC_ALLOCATOR=y
    CONFIG_HAS_IOMEM=y
    CONFIG_HAS_IOPORT=y
    CONFIG_HAS_DMA=y
    CONFIG_NLATTR=y
    CONFIG_GENERIC_ATOMIC64=y
MW RE: High speed USB port issue on MityDSPL138 - Added by Michael Williamson almost 16 years ago
Hello Mr. Csizmadia,
The Industrial I/O boards were originally designed to support client mode only for the USB 2.0 interface (USB0). This was why the connector is a B style instead of an A style. It was intended for a connection to a PC. As a result, we didn't design in a +5 V supply for that interface. This is being addressed in the next revision of the board, but unfortunately they are not yet available for general consumption.
If you need USB 2.0 host mode with +5V supply, you will have to modify the board and add a jumper from the USB 1.0 +5 supply to the USB 2.0 connector. This should work as long as you don't consume too much current between the 2 ports. The +5 supply will provide 500 mA of current. A couple of other customers have been successful with this approach.
Please accept our apologies. We didn't have the vision to support both host and client modes for that port when we designed the I/O card.
i believe we can supply schematics for the Industrial I/O module and the SoM with an NDA. You'll need to contact our sales guys about that (likely Tom Catalino).
Thanks.
